hi.
- I have successfully booted Armstrong Linux in HPS of cyclone V ,
- made a simple program for ram functionality .
I want to access ram data stored in address "00" using python in HPS.
Please provide me a sample/eg code. or documentation for the same.
Thank you.
Hi ,
Please try to use the general linux commands using wrapper os.system() in python.
https://superuser.com/questions/164960/how-do-i-dump-physical-memory-in-linux
and let us know the results.
entity pmuga_01 is
port (
CLOCK_50 : in std_logic;
AUX_LEDO : out std_logic;
DAT_LED : out std_logic_vector(3 downto 0);
LED : out std_logic
end entity;
architecture Behavioral of pmuga_01 is
signal counter : integer := 0;
signal clk_1Hz : std_logic;
signal aux : std_logic;
signal data : std_logic_vector(3 downto 0);
signal addr : std_logic_vector(7 downto 0);
signal output : std_logic_vector(3 downto 0);
signal wren : std_logic;
component pcycle
port(
address : in std_logic_vector(7 downto 0);
clock : in std_logic;
data : in std_logic_vector(3 downto 0);
wren : in std_logic;
q : out std_logic_vector(3 downto 0)
end component;
begin
ram : pcycle
PORT MAP (
address => addr,
clock => clock_50,
data => data,
wren => wren,
q => output
process(CLOCK_50) is
begin
if rising_edge(CLOCK_50) then
if counter < 25000000 then
counter <= counter + 1;
else
clk_1Hz <= not clk_1Hz;
counter <= 0;
end if;
end if;
end process;
LED <= clk_1Hz;
AUX <= clk_1Hz;
process(AUX) is
begin
if clk_1Hz = '1' then
AUX_LEDO <= '0';
wren <= '1';
data <= "1111"; -- data 1111 is stored in addr 00000000
addr <= "00000000";
else
AUX_LEDO <= '1';
wren <= '0';
addr <= "00000000";
DAT_LED <= output;
above VHDL code used to store data in ram which I created using ip integrator...
from mmap import mmap
MAPSIZE = 10
offset_mem = 0xFFFF0000
with open("/dev/mem", "r+b") as f:
mem = mmap(f.fileno(), MAPSIZE, offset=offset_mem)
packed_reg = mem[:]
print(packed_reg.encode('hex'))
this python code is used to collect data using python. i get address of on chip memory as 0xFFFF0000 from this link. https://www.intel.com/content/www/us/en/programmable/hps/cyclone-v/hps.html#topic/sfo1410068453374.html
but the output of python doesn't shows the correct data. at positio 0xFFFF0000
Hi
Please let us know what is the output obtained by the code at position 0xFFFF0000.
Anil
