6355 Discussions
Want to realize 1588 Solution,Which boards can support this solution?
Alice123
I am new to the 1588 over FPGA and I want to realize 1588 Solution. However, Arria V ST SoC seems to out of production.  Does Ariia V GX works ?  Which boards can support this solution?
SengKok_L_Intel
If you refer to the an739, it uses the Arria V SoC, where the software stack is running on Soc. The Arria V GX device does not have the SoC, if your custom board has external SoC or processor then you may consider implementing the software stack over there if possible
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an739.pdf
SengKok_L_Intel
If further support is needed in this thread, please post a response within 15 days. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
