6388 Discussions
We have been granted to access to Intel DevCloud with 2 FPGA's connected. After connecting with the cluster via SSH, not able to see the FPGAs. How to view them and how to use them to run ML algorithms? Thanks in advance!
Pallavi_S_Intel
Hi ,
Thank you for reaching out to us .
We have contacted our concerned team regarding this . We will get back to you soon.
Hazlina_R_Intel
To make it work you have to execute the following instruction:
lsipci | grep accel
fpgaconf -B 0x3b hello_afu.gbs
Above works on nodes n137, n138 and n139.
I hope this helps.
SGora1
I connected via SSH and tried running the above commands. They didn't work maybe because I am on the login node 'login-1'. By running 'pbdnodes' I am able to view all the compute nodes available but n137, n138 and n139 are not listed among those.
Kindly advise further. Thanks in advance.
Lawrence_L_Intel
Please refer to the material at https://github.com/intel/FPGA-Devcloud. Section 6.1 of the Access instructions explain how to find and login in to a compute node with FPGA cards attached. Thanks
