I instantiated the vip framebuffer II with the default address of 0x00000000. I am using the Tearsic DE10-Standard development board and Quartus 18.1 standard. I wrote a test program for Linux to exercise an LCD. I connected the framebuffer to the clocked video output IP block. I am wondering if the parameter buffer address is replaced by the frame address I set at run time. The screen goes black when the program presents the address to the framebuffer core.
Hi Ben,
Thanks for your update. As I understand it, when you use the example design from Terasic, there is no issue with the LCD display. Sorry as I am not really familiar with embedded area and also I am unable to comment on design implementation. However I will try my best to assist from the VIP perspective. Hope you could understand it.
Just would like to check with you on the following:
1. Just wonder if you if you have had a chance to try with a simple test design with Test Pattern Gen II -> Frame Buffer II -> CVO II -> LCD to see if there is any valid display on LCD? This would be helpful to ensure the FB II and CVO II IPs are working correctly prior to replacing the video source.
2. If #1 is working, you may start to replace the test pattern generator with your video source. This would help to narrow down the issue to video source if there is any issue observed.
3. You may also cross check your video data with the one from the Test Pattern Generator if #2 is not working. You may use signaltap to monitor the video data for cross checking.
Please let me know if there is any concern. Thank you.
Chee Pin
Hi Ben,
Thanks for your update. Glad to hear that you have managed to get the FB II working by configuring the memory base address to a value other than 0x0.
Sorry if there is any confusion. Regarding your previous post, yes, I have receive the email. I understand that you have tested with TPG II -> CVO II. Thus, I am suggesting to test by adding FBII in between, ie TPG II -> FB II -> CVO II. Get the FB II up and running, then only remove the TPG II from the system. However, since you have managed to root cause the issue, it would be great for you to continue using your resolution to avoid gating your progress.
Chee Pin
Hi Ben,
Just would like to follow up with you if there is any further concern. Please feel free to let me know if there is any concern so that we could further assist you. Thank you.
Chee Pin
Hi Ben,
As I understand it, it has been some time since I last heard from you. I would set this case to closed at this moment. Feel free to file a new case if you have any further question related to this request. Thank you for your understanding.
Chee Pin
Thanks lot for your update. I will set this case to close-pending. Please feel free to open a new case in future should you have any further inquiries.
Thank you.
