Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
What is the series of register WRs and RDs that must be done to activate the 10G Ethernet? Is there an example of using the MAC, PHY layers to activate the 10G port?
Just what are the registers i need to write to and the bits, and any reads to setup the 10G port to become active with a host computer connection.
Highlighted
Re:What is the series of register WRs and RDs that...
Hi Ageie1,
Thank you for posting in our Intel® Ethernet Communities Page.
Please provide us the model of the ethernet card that you want these registers for.
Kindly also provide us a background and the reason why you need to get the information.
We look forward to hearing from you. If we do not get your reply, we will follow up after 3 business days.
Alfred S
Intel® Customer Support
Highlighted
Re: Re:What is the series of register WRs and RDs that...
This is to activate the 10G SPF port on the Alteria 10 Arria Development Kit Board. What is the sequence of setting up the 10Gig E port. Activating through software. Which registers will give me a basic operation. I constructed a 1G FPGA and activated the FPGA 1G ethernet with a few writes to address in MAC, MDIO and i could construct a ethernet packet in FIFO and transmit to a host computer. I like to do the same with 10Gig E, but am having a problem doing so, i cannot get the data in FIFO to transmit over the port. Undoubtedly i am not setting up something correctly to activate the port as i did with the 1G FPGA port.
Ardie
Highlighted
Hi AGeie1,
Thank you for providing more information regarding your issue.
We have a dedicated forum for your concern.
So you will be better assisted, we will transfer your thread to the correct channel.
Thank you for reaching out in our Intel® Ethernet Communities page.
Alfred S
