6418 Discussions
What's the difference between "Production Edition" and "ES2 Edition"?
xxiao14
What's the difference between "Production Edition" and "ES2 Edition"? And what does the "ES2" mean? Thank you very much!
YuanLi_S_Intel
Hi Xin Xiao, Yes you are right. I would say is different revision =) Regards, YL
YuanLi_S_Intel
Hi Xin Xiao, Production Edition is much better than ES2 Edition in term of device's stability and functionality. Thank You. Regards, YL
xxiao14
Hi YL,
Thank you very much for replying. So ES2 is a kind of a test edition and both editions have the same function? And if a code can be run in a ES2 Edition chip, it would be able to be run in a Production Edition chip, right? Thank you very much!
YuanLi_S_Intel
xxiao14
