6153 Discussions
Where could I get new patch or license for N3000 IP?
ahaa
The IP cores of our Quartus were expired,which cause that we cannot compile our N3000 projects successfully.
Where could we get new patch or new license of N3000?
Thanks very much!
JonWay_C_Intel
You will need to re-download the 1.3.1 Acceleration Stack for FPGA Development and re-install the package.  The file is available from: https://www.intel.com/content/www/us/en/programmable/products/boards_and_kits/dev-kits/altera/intel-fpga-pac-n3000/getting-started.html
If you untar the latest 1.3.1 N3000 file - n3000_ias_1_3_1_pv_dev_centos_installer.tar.gz  You will see the following contents:
$ ls -al
total 8942084
drwxrwxr-x.  3 user user        100 Jan  6 13:12 .
drwxr-xr-x. 11 user user      8192 Jan  7 06:25 ..
-rw-rw-r--.  1 user user     218965 Jan  6 13:11 config_4.19_opae
-rwxrwxr-x.  1 user user 9156457935 Sep 10 11:25 n3000-1.3.8-4-dev-el7-setup.sh
drwxrwxr-x.  2 user user         44 Jan  6 13:12 N3000_supplemental_files
The file "n3000-1.3.8-4-dev-el7-setup.sh" contains the updated installer with new license files with 31-dec-2027 expiration.
By default the installer will remove the existing /inteldevstack, so if the user wants to preserve this directory, then mv the /inteldevstack directory to another location before running the installer.
The command to install just the N3000 Quartus Pro and license is:
$ sudo ./n3000-1.3.8-4-dev-el7-setup.sh -y -t quartus source --owner <user[: group]>
