6194 Discussions
Where does channel data stored when the AXI interconnect is busy?
efe373
Assume the AXI interconnect is busy at the moment, and there is a master that wants to read/write something to a slave. So, is this request stored temporarily at the master itself or at the master/slave interface or at the AXI interconnect? I assume these signals coming from channels should be stored in some FIFOs. However, I do not know where are these FIFOs.
If it is a design-specific problem, how Intel implements it?
aikeu
Hi efe373,
This will depends on your overall design to determine how the FIFO is handled in your system.
I do not have a specific answer to your question.
Similar reference to the handling of FIFO can refer to chapter 2 and 24 of Embedded Peripherrals user IP guide.
Embedded Peripherrals user IP guide link:
https://d2pgu9s4sfmw1s.cloudfront.net/DITA-technical-publications/PROD/PSG/ug_embedded_ip-683130-670523.pdf?Expires=1641532629&Key-Pair-Id=APKAJKRNIMMSNYXST6UA&Signature=Oy1Lr6ISYy6ExGSP8d-NOl6fQv6DPz0S36QFfs6fEB4ars8suDcpSAUJh5YULOdvjP8G45po7vhwXkC9NCSnXWslW6C4K5SQZ2dy6BGX-7HYqi4qlrROTxDK9IodpYlkq490lsDKVdjFZcUAKvcSlpUJ6zno7T2vjmNzZa4940UaU0e7GIRH...
Aik Eu
aikeu
Hi efe373,
I will close this thread if no further questions.
Aik Eu
