5780 Discussions
Where is the .qar file in AN830 example from the Design Store?
JCard19
click the link below and download the compressed file top_fpga.par file. It is missing the .qar file. Therefore the example cannot be loaded.
https://fpgacloud.intel.com/devstore/platform/19.3.0/Pro/an-830-intel-fpga-triple-speed-ethernet-and-on-board-phy-chip-reference-design-for-intel-stratix-10-devices/
sstrell
The .par file you download is a template file. As stated on that page, you have to install and use the design template using the New Project Wizard or just double-click it in newer versions of Quartus.
#iwork4intel
JCard19
I know that, I did it many times with other projects, but this project, AN830, is not complete. The .par file should contain 3 files but only two are available.
Vicky1
May I know below details,
  1. Which Quartus Pro version are you using?
  2. Which platform(Windows/Linux)
Please try again with template of the same version of Quartus Pro which is installed on your machine.
Here is Q19.1 Pro screenshot,
Please let me know if you have any different issue.
Vicky
