This isn't the first time to program an FPGA. and it fail while downloading the sof file. without adding the NIOS design was working fine. Can you explain to me why, If you can....
Can you please check the JTAG configurations. mainly I am suspecting the JTAg speed.
And also check the cable you are using, if everything is correct. I am open to review your design if you are welling to share with us (Screen shots are just fine)
Topic Options
