aocl program: Running reprogram from /home/root/opencl_arm32_rte/board/c5soc/arn
altera_fpga_manager ff706000.fpgamgr: timeout
Hi ,
If you can try the compilation on Ubuntu 16.04 or 18.04 that would be helpful , since the issues of compatibility of GLIBC can be avoided.
You can also check which version of GLIBC is currently installed in your system to cross verify.
Thanks and Regards
Anil
Hi
can you confirm that The MSEL settings for your board is correctly configured.
Thanks and Regards
Anil
I have conform the MSEL setting to pp32 bits.
Hi
Please set the MSEL to 01010
There is a similar issue observed in the following link
https://software.intel.com/en-us/forums/opencl/topic/850597
as mentioned there , can you refer to
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/soluti...
and try to reduce the JTAG frequency and let us know the results.
Thanks and Regards
Anil
I use URTA USB for reprogram the DE1_SoC board via minicom. So, How I can reduce the frequency of URTA or it not?
I generated .aocx file by using offline compiler.
If you are using an SD card with pre-built image and using minicom to login to it please let us know the same.
In that case you can try creating the SD card image with lower JTAG frequency configuration.
Also please try multiple OpenCL examples , like helloworld and simple programs, and let us know whether the issue is still coming.
Thanks and Regards
Anil
Thank you!!!
I have no idea creating SD card image with lower JTAG frequency configuration.
If you have some note on this idea please share with me.
Hi
You can check the following link on SD card image creation.
https://rocketboards.org/foswiki/Documentation/BuildingBootloader#Cyclone_V_SoC_and_Arria_V_SoC
Also if possible please use Ubuntu 16.04 and let us know , whether same issue exists.
The following guide will be helpful to get info about jtagconfig
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_usb_blstr.pdf
Thanks and Regards
Anil
Thank you very much!! I have great respect you.
I have some issue.
After I program FPGA with .aocx file it now successful configured. However, when I try to running host code the following error is generated. So,how I can fix it?
/run: /lib/libm.so.6: version `GLIBC_2.27' not found (required by ./run)
./run: /lib/libm.so.6: version `GLIBC_2.29' not found (required by ./run)
./run: /lib/libc.so.6: version `GLIBC_2.17' not found (required by ./run)
./run: /lib/libstdc++.so.6: version `CXXABI_1.3.8' not found (required by ./run)
./run: /lib/libstdc++.so.6: version `GLIBCXX_3.4.21' not found (required by ./run)
unfortunately, Upgrade OS Ubuntu 18.04 to Ubuntu 20.04.
Please help me!!!
Warm regrades!!
Guta
Hi ,
Thanks and Regards
Anil
THankyou for reply!
