hi:
Now,I have being study the DE2_TV,which is one of the DE2 board demo,in I2C_controller module,I have some problem as follows: ////////////////////////////////////////////////// wire I2C_SDAT=SDO?1'bz:0 ; case (SD_COUNTER) 6'd0 : begin ACK1=0 ;ACK2=0 ;ACK3=0 ; END=0; SDO=1; SCLK=1;end //start 6'd1 : begin SD=I2C_DATA;SDO=0;end 6'd2 : SCLK=0; //SLAVE ADDR 6'd3 : SDO=SD[23]; 6'd4 : SDO=SD[22]; 6'd5 : SDO=SD[21]; 6'd6 : SDO=SD[20]; 6'd7 : SDO=SD[19]; 6'd8 : SDO=SD[18]; 6'd9 : SDO=SD[17]; 6'd10 : SDO=SD[16]; 6'd11 : SDO=1'b1;//ACK /////////////////////////////////////////////////// in the code above: I cannot understand the code "SDO=SD",because if sd==1,I2C_SDAT will be "z",so how to output slave address? thanksLink Copied
Topic Options
