5539 Discussions
bemicro windows 7 64bit programmer
I am using the bemicro board from arrow. I get everything to compile, I have all the drivers. However, when I click on the programmer button and click hardware setup, the only option that I have avaliable to select is No Hardware, which doesn't work. Also, when I run the bemicro driver install, it says the registry key is missing for the jtag server.
Any help would be appreciated.
Hi!
I have the same problem, it will not work on 64-bit win7.
You should try with a virtual machine. I have made it work on a 32 bit win xp vmware virtual machine, and it is fine now.
Good luck, if you have any questions just ask it! :)
The Windows 64-bit driver is available on this thread:
http://www.alteraforum.com/forum/showthread.php?t=33736
It worked fine for me.
Cheers,
Dave
Thank you very much!
I haven't noticed that thread jet, but it saves me more than 20 GB space on HDD (no more virtual machine) :)
Adam
