Hi - I just began working with a Cyclone IV GX Starter Kit and attempted to compile the board test system (bts_general), but got the error:
Error: Port INCLK of Transceiver PLL Atom bts_general_sopc:bts_general_sopc_inst|tse_mac:the_tse_mac|altera_tse_mac_pcs_pma_gige:altera_tse_mac_pcs_pma_gige_inst|altera_tse_gxb_gige_inst:the_altera_tse_gxb_gige_inst|altera_tse_altgx_civgx_gige_wo_rmfifo:the_altera_tse_alt_gx_civgx_wo_rmfifo|altera_tse_altgx_civgx_gige_wo_rmfifo_alt_c3gxb_mlv7:altera_tse_altgx_civgx_gige_wo_rmfifo_alt_c3gxb_mlv7_component|altpll:pll0|altpll_ja81:auto_generated|pll1 cannot be connected to PLL Atom pll_125:this_pll_125|altpll:altpll_component|pll_125_altpll:auto_generated|pll1 After googling, the only relevant result seemed to be: http://www.altera.com/support/kdb/solutions/rd12132010_299.html I installed the windows version patch and verified that it seemed to be patching the correct files (c:\altera\10.1\quartus\bin\db_cut.dll), but despite applying the patch I still get the same compilation error. Is there some reason the patch did not correct the problem (are there any specific temp files I need to blow away?)? Anyone successfully compiled / programmed the board_test_system for this kit in quartus 10.1? Thanks in advance.Link Copied
Try bypassing the pll instantiated at the top level. Hook the 125 MHz clock input directly to the sopc system.
bts_general_sopc bts_general_sopc_inst ( .chipselect_to_the_tristate_lcd (lcd_csn), .flash_tristate_bridge_address (fsml_a), .flash_tristate_bridge_data (fsml_d), .flash_tristate_bridge_readn (fsml_oen), .flash_tristate_bridge_writen (fsml_wen), .select_n_to_the_ext_flash (flash_cen), .cs_n_to_the_maxII_interface (max2_csn), .ssram_bwn_to_the_ssram (ssram_bwn), .ssram_cen_to_the_ssram (ssram_cen), .in_port_to_the_button_pio (user_pb), .out_port_from_the_led_pio (user_led), .mdc_from_the_tse_mac (enet_mdc), .mdio_in_to_the_tse_mac (mdio_in_to_the_tse_mac), .mdio_oen_from_the_tse_mac (mdio_oen_from_the_tse_mac), .mdio_out_from_the_tse_mac (mdio_out_from_the_tse_mac), .led_an_from_the_tse_mac (led_an_from_the_tse_mac), .led_char_err_from_the_tse_mac (led_char_err_from_the_tse_mac), .led_col_from_the_tse_mac (led_col_from_the_tse_mac), .led_crs_from_the_tse_mac (led_crs_from_the_tse_mac), .led_disp_err_from_the_tse_mac (led_disp_err_from_the_tse_mac), .led_link_from_the_tse_mac (led_link_from_the_tse_mac), // .gxb_cal_blk_clk_to_the_tse_mac (pll_clkin_enet), <---- Here ... .gxb_cal_blk_clk_to_the_tse_mac (clkin_enet), .reconfig_clk_to_the_tse_mac (clkin_sys), .reconfig_fromgxb_from_the_tse_mac (reconfig_fromgxb_from_the_tse_mac), .reconfig_togxb_to_the_tse_mac (reconfig_togxb_to_the_tse_mac), // .ref_clk_to_the_tse_mac (pll_clkin_enet), <---- ... and here .ref_clk_to_the_tse_mac (clkin_enet), .txp_from_the_tse_mac (enet_tx), .rxp_to_the_tse_mac (enet_rx), .osc_clk (clkin_sys), .ssram_clk (ssram_clk), .reset_n (cpu_resetn) );
