6418 Discussions
bsp-editor not found in SoC EDS Pro 19.3
YTagu5
I'm starting my development with Arria 10 and I need to use bsp-editor. I have downloaded and installed SoC EDS Pro 19.3. However, I cannot execute bsp-editor in SoC EDS Command Shell. I looked into C:\intelFPGA_pro\19.3\embedded\host_tools\altera\preloadergen. In that folder, I see bsp-generate-files.exe, bsp-query-settings.exe, etc... except the bsp-editor.exe.
How may I install bsp-editor?
Yoshitaka
EBERLAZARE_I_Intel
May I know from which link you downloaded the SoC EDS Pro from?
I have checked in my directory there is a bsp-editor.exe in my folder.
I recommend that you re-download the software again and install here:
http://fpgasoftware.intel.com/soceds/
In the mean time I'll try to re download and reinstall to check again if everything has installed properly.
Regards.
YTagu5
Hi, el.ign,
Thank you for your reply.
Yes, last time I have downloaded SoC EDS Pro from that link.
This time, I uninstalled SoC EDS once, then reboot the computer, download​ and installed again.
But bsp-editor.exe was not found. Instead, I see "com.altera.embeddedsw.bsp.editor.jar" in preloader folder. The situation does not change.
By the way, each time installing SoC EDS Pro, the installer gives no error and finishes. However, when I try to use SoC EDS Command Shell, the .bat file won't run because cygwin is not installed automatically.
So I install cygwin manually, reading the instruction in "C:\intelFPGA_pro\19.3\embedded\cygwin_setup" folder. Does this making problem?
Best Regards
EBERLAZARE_I_Intel
If you are using Windows to install the SoC EDS 19.3, you will need to install the cygwin manually. Please follow the steps to install the SoC EDS below:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_soc_eds.pdf#page=12
Have you try running SoC EDS and bsp editor after installing the cygwin?
EBERLAZARE_I_Intel
Hi Yoshitaka,
Starting from SoC EDS Pro version 19.3 and SoC EDS Standard version 19.1;
Our Stratix 10 SoC and Agilex does not use SoC EDS bsp-editor . However, the bootloader generator(bsp-editor) is still used for Cyclone V and Arria 10 and the steps to build are available below:
https://rocketboards.org/foswiki/Documentation/BuildingBootloader
Thanks!
YTagu5
Hi el.ign,
Yes, I installed the cygwin manually. Last time, I read the instruction in C:\intelFPGA_pro\19.3\embedded\cygwin_setup and manually installed. This time , I followed the instruction on the URL Link you gave me.
But bsp-editor was not found on both cases. When I try to find bsp- related tools in the shell by a command completion with Tab key, I got this result:bspnotfound.PNG
Othe bsp- related CUI tools are seem to be installed.
I'm using Arria 10. Because the manufacturer of my board recommend using bsp-editor in a reference design document, I prefer to use bsp-editor.exe, not the CUI tools described in that rocketboards wiki URL.
Kind regards,
EBERLAZARE_I_Intel
If you preferred the bsp-editor GUI, please proceed to use the 19.1 version of SoC EDS. The bsp-editor GUI is removed in 19.3.
I have confirmed in 19.1 SoC EDS, the bsp-editor GUI is available.
FYI, using the command line in the link below to generate the bootloader will use newer bootloader as compared to the bsp-editor GUI which is using the old version:
Best Regards.
YTagu5
Hi, ​
Thank you so much for that information! I will download install version 19.1.
Best regards.
