5930 Discussions
cannot printf "hello world"
hi:
In niosII eclipse,We always bug our software using "printf" command,I make the SOPC system using CPU,SDRAM,JTAG_UART,other components,sometimes according to the requirment of project,I delete or add the "other component ",the base project is the altera demo.
maybe the NiosII eclipse BUG, or maybe I overlook something,sometimes will generate puzzled results,though I have set stdin/stdout/stderr to JTAG_UART.
the sad problem is "cannot printf " ,though I use the simplest NiosII temple,and there is no single warning or error in console window(as attachments),in attachment named "console.bmp",download successfully,but cannot printf "hello world"
PS:the project is based on the old project which is OK,I only delect some components in SOPC.
1. The lightweight libraries do not offer printf() function. Something like that.
2. Are you sure you use jtag... for std_out in system library settings ?
hi:
thanks for your suggestion~!
the setting I have checked,there seems no problem,
the problem is always there,maybe I could find the reason later~
ps: may I ask you a question,that is : Have you ever used VIP demo?
thanks a lot!~
--- Quote Start ---
hi:
thanks a lot!~
--- Quote End ---
No, I have never used VIP demo.
For your problem, maybe the software doesn't start or doesn't boot.
I know that after downloading to FLASH, the CPU is "paused" and I need to reboot the target board. This operation is normal.
yes,maybe you are right
clear the NiosII eclipse,or build the software again ,it can print OK
sometimes,I focus strongly on hardware !~
