All support for Intel NUC 7 - 13 systems has transitioned to ASUS. Read latest update.
cyclone 10 gx fpga
mehta_expai
I had downloaded  Quartus prime pro and the device installation file for cyclone 10 gx.
When i have installed Quartus prime pro & started new project ,but when the board selection window is came, the selection for board is not there. So i have downloaded the board file for cyclone 10 gx from intel website.. with a name of  cyclone 10 gx kit collateral.
I don't know, how to add this board file in Quartus prime software or where i have to copy this board file in main files.
sstrell
If you are saying that you have a development kit and you're not seeing the board in the New Project Wizard, I've found that few of them end up appearing there.  You may have to select the device on the board and manually create I/O and other assignments.  Or you can look for a project template (.par) that might be available for your board.
sstrell
