cyclone 10 pcie an829
ljian6
hello, everyone ,I am use the cyclone 10 GX FPGA Development Kit ,when I use the an829 design example into the board, the pc's screen become like this :
EFI Shell Version 2.31 [4.633]
Current running mode 1.1.2
Map: Cannot find required map name
Press Esc in 5 seconds to skip startup.nsh, any other key to continue
the step like this:
1power down the pc and plug in the board
2power on the pc then download the .jic(sof transfer to) into the fpga ,power down the pc
3 power on the  pc and than the screen  like the above mentioned.
Is there some wrong in my operation, anybody could help me to fix it?thanks a lot!
Vicky1
Everything is there, just refer this application note for cyclone 10 GX FPGA Development Kit,
  1. Check the DMA Reference Design Hardware and Software Requirements
  2. working with the reference design : download the reference design from below link ,take care of design templates & then compile the project, https://fpgacloud.intel.com/devstore/platform/2183/
  3. DMA Procedure Steps
  4. Then refer the setting Up the Hardware
Let me know if this has helped resolve the issue you are facing or if you need any further assistance.
Best Regards
Vikas Jathar
(This message was posted on behalf of Intel Corporation)
