i am using altera cyclone 5 device, which is programmed through epcs16. initially for 2-3 days my card works well, but after that cyclone 5 is sending dclk signal again and again. i changed epcs16 and also resoldering cyclone 5, but the problem is not solved. i am facing this problem in 2-3 cards. kindly suggest me the appropriate solution for this.
Hi pmang2,
I suspect this issue due to problem with Serial Flash Loaderr (SFL) file in Quartus.
The workaround is to use user SFL with additional timing constraints.
Please refer to following KDB:
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/soluti...
Thanks.😉
For more complete information about compiler optimizations, see our Optimization Notice.
