5784 Discussions
debugger problem using DS-5 and Byteblaster - cannot connect?
MCOUNSELL
Does anyone have any ideas of the cause of this that I see quite often?
The target hardware identity could not be verified. Please check that the target being connected to is of type Cyclone V SoC (Dual Core)
Debugging fails to start with this error dialog.
Mike
Ahmed_H_Intel1
Hi, If you are debugging across JTAG, please check the JTAG frequency. It is the most common issue. Regards,
