is there any possibility to purchase only the board of developent kit without the FPGA itself ? ( I want to perform system test on multilple ep2agx125ef29c6nes components and the develoment kit I want to use is dk-dev-2agx125n )
thanksLink Copied
How would you test the components? You'd have to solder them to the board.
Jake- Mark as New
good point , I want to use some kind of socket , so I can
test many FPGA's on the same board . I want to use the dev kit , since it comes with program that tests the hardware itself very easily.
Topic Options
