I recently upgrated my quartus 9.0's project from Cyclone II de1 to stratix II dev kit. I'm using the NIOS processor in my project . my NIOS memory is a DRAM, which worked fine on the DE1 when it was connected, but for somehow I cant get my stratix II sdram to work. I get the "verify failed" massage about the sdram addresses. In addition I cant connect the PLL to the SOPC,but I get compilation errors about the pll. it only works when I connect the PLL from outside the SOPC builder. I know that timing is importent to the SDRAM. I know that I need to do phase shifting to the clk, but it still doesn't work. If someone had this problem and it was solved, I would like to know how. thanks alot, AsafLink Copied
Topic Options
