6418 Discussions
devkit startix5 pcie-demo issue
Hi all,
i tried to run demo pcie example that shipped with kit but it stall at ltssm: detect.Active !! , i know that was issue at ACDS less than 12 , but i'm using 13
the example provided use hard IP pcie with X8 and gen2 , Avalon_st as application and print out link state and on board LED .
have anyone face such issue ?
thanks,
Amr
do you re-generate pcie-core?
--- Quote Start ---
Hi all,
thanks,
Amr
--- Quote End ---
yes i generated another one with same connection of example ,but i've figure out problem cause :
we must set test_in[5] = 0;
to allow pcie enter compliance mode
the another issue now that Ltssm stall at Polling.Compliance(3) state !!
i doubt that the cause of this problem from either "reconfig_xcvr_clk" as it set to 125MHz and have timeQuest -ve slack or "I\O pin standard" as it silghtly different from rerferance manul of kit
thanks,
I am having a similar issue with the Cyclone IV devkit. I have set test_in to be 40'h88, and on certain ports of my Dell computer the board stalls on the LTSSM state "Polling.Compliance".
Any help would be appreciated.
this values of test_in that make my dev kit run successful training:
test_in[4:0] = 5'b01000;
test_in[5] = 0;
test_in[31:6] = 26'h2;
and please make sure of pcie lane switch of your kit . it should match your design's lanes.
thanks,
Amr
