eCPRI ORAN integration
chandusri
Hi Team,
This post is regarding eCPRI and ORAN ip cores integration.
I am trying to integrate eCPRI and ORAN ip cores in Arria10 FPGA. it will be of great help if you guys could share any integration/paring documentation for above mentioned ip cores.
Thanks and Regards,
Chandu sri.V
Kshitij_Intel
Hi Chandu,
I am sharing link for example design. The design example allows you to simulate, compile, and test your O-RAN IP instance on various development boards. The design example includes Ethernet IP, eCPRI IP, eCPRI IOPLL, PTP IOPLL, and a test wrapper.
O-RAN Intel® FPGA IP Design Example User Guide
Thank you
Kshitij Goel
Kshitij_Intel
Hi Chandu,
As We do not receive any response from you to the previous reply that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread.
Thank you.
Kshitij Goel
Hari_Krishna
Does ORAN IP supports S/M-plane processing of ECPRI and ORAN????
How PTP synchronization happens with the Grand master with ORAN IP core???
Seperate PTP slave module has to be there? or ORAN IP inbuilt any PTP support is there Please clarify ???
In document, i=Only C/U plane processing is supported by ORAN IP, what about S-plane PTP sync info??
Please clarify.
Thankyou,
Hari.
