Hello
I'm trying to connect the evaluation kit to the internet, but it is not able to get an IP address by dhcp looking at the packet it look lik it has a wrong mac address ff:ff:ff:ff:ff:ff did I miss something in the installation? Gilles Simond Observatoire de GeneveLink Copied
This is a broadast address. Are you sure it isn't the destination MAC in the dhcp request address?
Which evaluation kit do you have?- Mark as New
This is a Nios Embedded Evaluation Kit Cyclone III edition
and I was looking at the dhcp server log, so this is really the source MAC once it was 07:ff:ff:ff:ff:ff, see the log line below daemon.log.0:Mar 17 16:43:04 obsfrog dhcpd: DHCPDISCOVER from 07:ff:ff:ff:ff:ff via eth0: unknown client then it was ff:ff:ff:ff:ff:ff ????? daemon.log.0:Mar 17 16:46:57 obsfrog dhcpd: DHCPDISCOVER from ff:ff:ff:ff:ff:ff via eth0: unknown client we expected it to be something like 00:07:ed..... (altera device) on board near RJ45- Mark as New
You can try and erase the last page of the flash, and then the Nios application should ask you to type the board's serial number to generate a new Mac.
This will only work if you are using an example software with network_utilities.c
Topic Options
