6388 Discussions
file missing compile error Cyclone X GX FPGA development kit example qts_pcie_sfp
TWatt
I have a Cyclone X GX FPGA development kit. I am trying to compile one of the example projects in Quartus (qts_pcie_sfp) but am getting an error (see below):
Error (13225): Can't open VHDL or Verilog HDL file "ip/xcvr_test_system/xcvr_test_system_data_pattern_generator_0/altera_avalon_data_pattern_generator_180/synth/xcvr_test_system_data_pattern_generator_0_altera_avalon_data_pattern_generator_180_xz7276a.v"
Error (13223): Verilog HDL or VHDL error: cannot open verilog file 'ip/xcvr_test_system/xcvr_test_system_data_pattern_generator_0/altera_avalon_data_pattern_generator_180/synth/xcvr_test_system_data_pattern_generator_0_altera_avalon_data_pattern_generator_180_xz7276a.v'
The file is there, so how do I resolve this error?
AnandRaj_S_Intel
we acknowledge the issue​, Will come back on this issues.
qts+pcie_sfp error.JPG Best Regards,
Anand Raj Shankar
(This message was posted on behalf of Intel Corporation)
JosephC_Intel
Hi Twatt,
Our first level engineer duplicated this issue internally. Therefore, we've escalate this to our engineering team. An internal bug was opened and we will keep you posted once we make progress.
Joseph
Intel Customer Support
610018
JosephC_Intel
Hi Twatt,
Just to let you know we are not hearing back from our engineering yet. We will continue to follow up this...
Joseph
Busy
I've got same error using NIOS2 CPU (NIOS2 + Cyclone 10GX220 + Quartus 18.1). Did you resolve your problem?
Many thanks.
AnandRaj_S_Intel
The error is due to directory path length by having smaller working directory / path length we can solve it.
Anand
