- Email to a Friend
So I have an Arria V SOC Dev Kit and am struggling with it.
I have the DIP switches set as per the kit user guide. I am trying to run "Getting Started with Hardware Library" section of the SOC EDS User Guide I can load the code, and the DMA setup runs OK. The FPGA setup first fails because the MSEL switches are not set as expected (0). So I try again with them set at the four values corresponding to each of ALT_FPGA_CFG_MODE_PP32_FAST_AESOPT_DC ALT_FPGA_CFG_MODE_PP32_SLOW_AESOPT_DC ALT_FPGA_CFG_MODE_PP16_FAST_AESOPT_DC ALT_FPGA_CFG_MODE_PP16_SLOW_AESOPT_DC and every time get a log of e.g. INFO: Setup FPGA System ... INFO: MSEL [2] configured correctly for FPGA image. INFO: FPGA Image binary at 0x201e0e0. INFO: FPGA Image size is 2275970 bytes. ERROR: Setup of FPGA return non-SUCCESS -2. That the examples and instructions don't work out of the dev kit box is very disappointing. Can someone from Altera please help. Thanks.- Tags:
- Intel® Arria®
- soc
Topic Options
