5547 Discussions
has anyone had issues programming Cyclone 10 GX FPGA using Cyclone 10 GX FPGA Development Kit?
LGonz14
I'm currently working with the Cyclone 10 GX Dev kit for a development project and I'm having issues with the JTAG chain ​after programming the FPGA in Active Serial mode. The JTAG chain is broken after programming the FPGA only once and now I can't figure out how to restore the JTAG chain. I'm using the latest Quartus prime software v18.1. Has anyone had a similar problem? any feedback would be greatly appreciated!
Thank you!
ShafiqY_Intel
Hi LGonz14,
Can you kindly try to change your TCK frequency to 6 MHz (default value)?
Kindly try it out with your design and let me know the result.
Thanks😉
LGonz14
Hi MShafiq, Unfortunately, setting the TCK frequency to 6Mhz doesn’t make a difference because the programmer gives me the following error message: Error(209040): Can't access JTAG chain Regards, Luis A. Gonzalez R&D Department Staff Sr. Electrical Engineer (DSP/FPGA) Beckman & Coulter, Inc. 11800 SW 147th Ave Miami, FL 33196 Tel: (305) 380-3787 [cid:image002.jpg@01D2125B.BDE54990]
ShafiqY_Intel
Hi Luis,
Can you try to change the MSEL and power-up the board?
This to ensure the board still can detect the JTAG chain.
If can’t detect, mean your board is dead.
