hi
I want to know how i can use multiport triple speed ethernet with multi channel shared memory if there is any example please give to meLink Copied
--- Quote Start --- hi I want to know how i can use multiport triple speed ethernet with multi channel shared memory if there is any example please give to me --- Quote End --- Hello, I also stuck in the same issue, did you reach anything? Thanks & Regards.
I have the same issue. Was there anybody able to use TSE multichannel configuration?
I'm wondering that Altera does not offer a simple reference design for that issue or do I miss something?
