5930 Discussions
how I can fix LABs requirements? I use the DE1_soc board, OS is ubuntu 18.04, and the intelFPGA_18.1 standard version. when I was trying to Compiling for FPGA then the following error generated.
GTese
aoc: First stage compilation completed successfully.
Compiling for FPGA. This process may take a long time, please be patient.
Error (170012): Fitter requires 5692 LABs to implement the design, but the device contains only 4191 LABs
Error: Cannot fit kernel(s) on device
EBERLAZARE_I_Intel
Based on my knowledge, you may need to remove some logics to optimize and fit your design.
Is there any other error during your compilation?
GTese
Thanks!
I have optimized my kernel code and it work now.
The other error when I try to compiling as emulator the following error was generated.
aocl-clang: error: unable to execute command: posix_spawn failed: No such file or directory
aocl-clang: error: linker command failed due to signal 1 (use -v to see invocation)
aocl-clang: note: diagnostic msg: Please submit a bug report to http://llvm.org/bugs/ and include command line arguments and all diagnostic information.
aocl-clang: note: diagnostic msg: Error generating preprocessed source(s) - no preprocessable inputs.
Error: Optimizer FAILED.
Refer to My_Kernel/My_Kernel.log for details.
EBERLAZARE_I_Intel
Helo,
I could not find the exact workaround regarding your error, it could be that there is a conflict of a symbolic link that is wrongly represented, can you check the below discussion if it is related to yours?:
https://github.com/darlinghq/darling/issues/170
GTese
Thank you!
Really, I appreciate you for great help.
It is working for me.
