5931 Discussions
how to assing HPS_CLK1 as system clock?
scong4
Hi
I want to assign HPS_CLK1 as system clock , but I can't find it from pin list in the Pin Planner.
EBERLAZARE_I_Intel
May I know which Quartus Version you are working on?
Are you using your own design or from an example designs?
scong4
Hi
I use Quartus Prime 18.0 , the attachment file is my full project , it refer to the examples design .
Thank you
EBERLAZARE_I_Intel
I will check the design out. Is the design your own or you get it anywhere from the web?
scong4
EBERLAZARE_I_Intel
Noted that.
EBERLAZARE_I_Intel
If you cant find it on the Pin Planner, you may need to recompile your design in Qsys/Platform Designer.
If you are looking for more of our example design, you may find it here:
https://fpgacloud.intel.com/devstore/
