6309 Discussions
how to program the external flash memory in the max10 fpga
AKAYA
I have tried to write the UFM flash memory. Now i need to try to program the external flash for the max10 fpga.
It should be able to write into the qspi flash memory. how can we write into the qspi flash memory
kindly waiting for the reply..
JohnT_Intel
Hi, You should be able to write into external flash by using the Generic Serial Flash Interface Intel FPGA IP where you can the user guide from https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-gen-sfi.pdf
