All support for Intel NUC 7 - 13 systems has transitioned to ASUS. Read latest update.
5849 Discussions
how to use TSE for 1000M model
CJere3
I generated the example test project but most Verilog files are encrypted​.I just want to send and receive data through 1000M Ethernet mode,I don't want to control  TSE ip by nios or hps. does intel has the Design_Example?as I know ,does TSE ip core only implement UDP protocal?how can I ping it,or TCP/IP protocal.can I sent datas from a PC without ARP response?
SengKok_L_Intel
Hi Chen, You can also refer to the AN647: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an647.pdf The example design is just to validate the TSE IP functionality (MAC and PHY layer) . The UDP/TCP IP is at transport layer of the OSI model. Therefore, TSE IP is not implement anything out of MAC and PHY layer. Regards -SK
CJere3
hello,
I read the example design for a few days.i can't understand the crcgen_dat32  in eth_gen.does the TSE generate the CRC automaticly?so why still use crcgen_dat32  function?
SengKok_L_Intel
Hi Jeremy, Yes, as per the Ethernet spec, the MAC responsible to generate the CRC for the data package. Regards -SK
