hi.I have some problems in FPGA . Now i am debugging my application using VJTAG. but I cannot get the device name using get_device_names'
The command is exec C:\\altera\\10.0\\quartus\\bin64\\quartus_stp --tcl_eval get_device_names -hardware_name USB-Blaster[usb-0]
some errors happen. In the attachment you will see it.how I solve it?the quartus II version is 10. FPGA EP3C25Q240
- « Previous
- 1
- 2
- Next »
Does quartus_stp --tcl_eval get_device_names -hardware_name usb-blaster[usb-0] work in xterm?
I'm sorry, what i meant is command line interface.
get_device_names -hardware_name [lindex [get_hardware_names] 0]
Do you manage to run the command get_device_names -hardware_name [lindex [get_hardware_names]0] ?
It seems like you can get the device name by executing on the command line interface.
Are you using Quartus II software version 10? Can you try in the latest version of the software and see the problem persists?
May I know if you have any updates?
Do you see any error message?
According to https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_virtualjtag.pdf (Page 6), you can use the Virtual JTAG IP core in tandem with other on-chip debugging applications, such as the Signal Tap logic analyzer, to increase debugging visibility.
- « Previous
- 1
- 2
- Next »
