I am currently working on the GSRD for an Htile S10 -
Stratix 10 SoC H-Tile GSRD | Documentation | RocketBoards.org
I am working on building the SD Card version, and hit a snag during the GHRD. After following the steps referenced in the GSRD and using the git files from the following -
https://github.com/altera-opensource/ghrd-socfpga
I have generated each of the output files
- ghrd_1sx280hu2f50e1vgas.sof - FPGA SOF file, without HPS FSBL
- ghrd_1sx280hu2f50e1vgas_hps_debug.sof - FPGA SOF, with HPS Debug FSBL
- ghrd_1sx280hu2f50e1vgas.pr_partition_0.rbf - PR bitsream for the baseline persona
- alternate_persona.pr_partition_0.rbf - PR bitstream for the alternate persona
except for the "ghrd_1sx280hu2f50e1vgas_hps_debug.sof", which is needed in the next step "building core rbf". I have come to the conclusion that it is because my build is not generating a file called "hps_debug.ihex". I am wondering why this file is not being generated.
I was more confident that the problem was this .ihex file when I came across this archive -
Index of /ghrd_release/stratix10/ (rocketboards.org)
specifically the htile_devkit_ghrd from 12-NOV-2022, which includes this missing "hps_debug.ihex" file, and when running the scrub, generate and make all commands, generating the "debug.sof" file perfectly. When I add this .hex file into my design it also runs perfectly. What am I missing?
Overall my goal is to get this default git build from the GSRD H-tile to generate the "hps_debug.sof" so I can continue.
Hi All,
If this occurs to anyone, please note that the work around I have been using is to run this command...
quartus_pfg -c -o hps_path=software/hps_debug/hps_debug.ihex output_files/ghrd_1sx280hu2f50e1vgas.sof output_files/ghrd_1sx280hu2f50e1vgas_hps_debug.sof
Please note that you need the .ihex file I mentioned which can be obtained from the link in the first question on this thread.
James
Hi james57,
I will try to build on my side to see if got the similar problem that you encountered.
Aik Eu
Hi james57,
I have tried to build that part and I also dont have the ghrd_1sx280hu2f50e1vgas_hps_debug.sof in my output files. I will try to check with the team regarding this.
Aik Eu
Hi james57,
I am consulting the team regarding this matter and will get back to you as soon as possible.
Aik Eu
Hi james57,
After I consulted my team and tried to build the GSRD again I managed to get the ghrd_1sx280hu2f50e1vgas_hps_debug.sof - FPGA SOF
I tried to remove and rebuild everything from zero again and I managed to get that file in the output folders.
my previous attempts might encountered some issue where I may have source the wrong version of tools.
To make it clear, I try to make sure my quartus and nios2_command_shell.sh version used is the same as the GSRD.
Make sure executing all the steps from Setting up Environment & Building the Hardware Design
Do let me know if there is any problems.
Aik Eu
FYI
HI @aikeu
I have been trying on my own as well and have been able to create it as well from time to time but not consistently.
Beyond that I am only able to create it while using the 1sx280hu2f50e1vgas board specified, none of the others. Weird.
Thank you for your help.
I will let you know if I have any more concerns.
James
Hi james57,
I am closing the thread for now since the issue has been resolved on your side. Do consider re-open a new thread if there is new follow up.
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 4/5 survey.
Aik Eu
Hi All,
James
