i am using arria 10 development kit. if i program the sof file through programmer i am getting the error as
Error (209015): Can't configure device. Expected JTAG ID code 0x02E860DD for device 1, but found JTAG ID code 0x02E660DD.
Make sure the location of the target device on the circuit board matches the device's location in the device chain
can any tell what is the issue
Hi Anuradha C,
May i know are you using the USB Blaster II to program the development kit? If it so, can you try to change the TCK frequency to 6MHz.
You may refer to link below for the steps to change TCK frequency:
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/soluti...
Thank You.
YL
hello sir,
i am not using usb blaster 2 to program the device
Also in the Programmer, make sure the tool is detecting the device correctly. Click Auto Detect and make sure to select the correct part number, if requested.
