All support for Intel NUC 7 - 13 systems has transitioned to ASUS. Read latest update.
5844 Discussions
i lost the permission to using AOCL and Quartus license, what should i do ?
MAyou
after formatting my laptop i lost the permission for using my AOCL and Quartus license , what should i do ?
KhaiChein_Y_Intel
May I know what version and edition of the software you are using? Do you see any error messages?
MAyou
Hi ,
i have quartus II 14.0 and AOCL 14.0 too
I was working with this version , everything was okay until i formatted my laptop.
I compiled a lot of kernels with Altera Offline Compiler (AOC)  and i made them run in DE1SoC
I still have my licenses .
MAyou
the error message
Error: aoc: Can't find a valid license for the Altera SDK for OpenCL
KhaiChein_Y_Intel
Hi MAyou ,
Have you try using the latest version of the software, v18.1?
MAyou
Hi YY,
Not yet.
I have to fix this license problem because i already got it 3 months ago, so it’s still available.
KhaiChein_Y_Intel
Hi MAyou,
Can you share the license.dat file?
MAyou
i thought that problem was from my laptop's name cause it was changed after the formating, so i updated my license for generating another one with my new laptop name's , but sadly not working
KhaiChein_Y_Intel
Hi, Can you check if the Host ID in the license file is the same as the Host ID for your new laptop? Can you share the license.dat file or upgrade to the latest version as the OpenCL SDK in the latest version does not require additional license if you have the Intel Quartus Prime software license. Thanks.
MAyou
Hi YY,
The problem is solved by returning to ubuntu 14.04 LTS
Thank you for your help.
