6410 Discussions
is signalTap available in S10 SOC GSRD?
LChen23
Dears
There is /s10_soc_devkit_ghrd/cti_tapping.stp file,  But it can not work.
Does anyone try to use signalTap in S10 SOC GHRD? and meet the same issue?
everything else function is OK, such as config SOF+FSBL, Linux boot....
EBERLAZARE_I_Intel
Can you share the Quartus version that you worked on?
Also, how did you initiate the STP file, did it reported any error or hang ups during opening of the file, etc?
LChen23
The STP file is in the GRSD pkg.
Just use signal tap ii to open it.
Quartus Version is 20.1pro
if you have board on hand, you could have a try. if you can capture the signal wave, please advice how you process it.
thanks
EBERLAZARE_I_Intel
Do you have the licenses for Quartus? How did you connect/program the S10 board?
