Community
cancel
Showing results for
Search instead for
Did you mean:
Honored Contributor I
nis2 dev kit sdram verify failed
I am using Nios2 dev kit(cyclone2), and quatus8.1,
could rebuild sopc and compile example nios2 standard project successfully.
but encountered the following problem when run sample application
Downloading 02100020 ( 0%)
Downloading 04000000 ( 0%)
Downloading 04010000 (65%)
Downloaded 98KB in 1.7s (57.6KB/s)
Verifying 02100020 ( 0%)
Verifying 04000000 ( 0%)
Verify failed between address 0x4000000 and 0x400FFFF
Leaving target processor paused
I've found there is some post about verifi failed problem,
but that seems because of customized H/W,
I just used altera dev kit and sample project.
so is it physical H/W problem?
Could someone help me ? Thanks!
I have the same problem, so does anyone know that?
