5780 Discussions
pac n3000 8x10G failed to connect with 40G server net card with 1x40G optical module and fiber
fzhan51
server_n3000( pac 8x10G)<---1X40G optical module and fiber--->Server40GbE , led lights on Server40GbE
are out, while the led lights is on when use the same optical module and fiber to connect the two ports within Server40GbE
JonWay_C_Intel
When you connect the 1x40G cable to the N3000. what is the output of fpgainfo phy? UP or DOWN?
fzhan51
I just found that result changes all the time,
e.g.1 e.g.2 e.g.3
Port0 10G           : Up   : Up    : Down
Port1 10G           : Down   : Up : Down
Port2 10G           : Down   : Up     : Down
Port3 10G           : Down   : Up    : Down
Port4 10G           : Down : Down  : Down
Port5 10G           : Up          : Up       : Up
Port6 10G           : Up          : Up       : Up
Port7 10G           : Down     :Down   :Down
JonWay_C_Intel
Hi @fzhan51​ , When you say 1x40G, it is only 1 port at 40G, right?
Or, Do you mean 4x10G instead? Because the the card can only support 10G per port.
fzhan51
1 port at 40G , 4X10G fiber test sucess. now I am confused.
JonWay_C_Intel
1 port at 40G --> it makes sense it will FAIL because the card supports 10G per port
4 port at 10G each --> it makes sense it will PASS because the card supports 10G per port
Im not sure there is such cable as 1 port at 10G --> then this will further confirm my explanation.
Btw, 1x40G is NOT EQUAL to 4x10G !!
fzhan51
Port0 10G           : Down
Port1 10G           : Down
Port2 10G           : Down
Port3 10G           : Down
Port4 10G           : Down
Port5 10G           : Up
Port6 10G           : Up
Port7 10G           : Down
Retimer A Version       : 101c.1064
Retimer B Version       : 101c.1064
