6267 Discussions
problem with bsp generation after qsys modification
DTebo2
i have a problem with bsp generation after qsys modification;
During conpilation i have this error :
SEVERE CPU "nios2_qsys_0" reset memory "avl_bridge_slave_full_mm" has no matching memory region
how can i match the memory region? there are no error after qsys generation...
job is on cyclone V, quartus prime 17.1
Thank you in advance for your answers....
MEIYAN_L_Intel
I would like to know do you modified the BSP in Qsys system?
May I know what have you change and can you list down the flow?
Also, can you attached the full design here for further investigate?
DTebo2
hi,
Thank you for your answer. We did not modify the BSP (the native BSP) only some interface of the qsys core.
Please see attachements
MEIYAN_L_Intel
In the Qsys system, I saw the Nios II processor with reset vector memory is assign as "avl_bridge_slave_full_mm".
Based on the error message, can you try to connect the avl_bridge_slave_full_mm to an on-chip RAM?
