Hi all,
I use tse to transmit the data to my 3c120 board, and my problem is that which output pins are the data transmitted, i see there is "fsa","fsd","enet_rxd[3:0]", what's their difference? Also, i see the ddr2_dq pin, can i access the data directly from that? Thanks! JeorgeLink Copied
I assume you have the user's guide for the board. I think you're referring to this board:
ftp://ftp.altera.com/outgoing/devkit/cycloneiii_3c120_dev_kit-v9.0.2.exe The board uses a Marvell 88E111 10/100/1000 ethernet PHY. This uses a GMII interfaces. Looking at the example projects, these are the corresponding pins: // ethernet interface enet_mdc, // mdio clock enet_mdio, // mdio data enet_rx_clk, // receive clock enet_tx_en, // transmit enable enet_gtx_clk, // 125MHz transmit clock (for gigabit) enet_rxd, // receive data enet_txd, // transmit data enet_rx_dv, // receive data valid enet_resetn // reset (negated) Jake- Mark as New
Thank you Jake! So the pin i mentioned like fsa is of no use if i want to access the data?
Another problem is that why the enet_rxd/enet_txd is a [3:0] one? that means the data is stucked at a 4 bit width?- Mark as New
I must make a correction. It appears that on your board, the pins are connected to the RGMII interface of the PHY. The difference being that the interface runs at double-data rate. So while the data bus in either direction is 4 bits, data is transferred on both edges of the clock producing 8 bits per clock.
If you intend to interface with the ethernet PHY, you really ought to consider using an ethernet MAC like the Altera Triple-Speed Ethernet MAC. If nothing else, you ought to read over it's documentation so as to understand the interface. http://www.altera.com/literature/ug/ug_ethernet.pdf Jake
Topic Options
