5915 Discussions
questions about DMA transmition
hi:
I want to transmit data from FIFO to sdram by DMA in SOPC builder.
in NIOSII eclipse,
if((tx=alt_avalon_dma_send(txchan,(void*)tx_data,0x1000,NULL,NULL))<0)
printf("failed to send data from fifo \n");
always printf: failed to send data from fifo
I add "while(1)" to contain this code:
while(1)
//the number of translated data at one time
for(j=0;j<=100;j++)
if( j==90)
exit(1);
but it always failed ...
is there somebody can give me any hints? thanks~
hi,gurus
I have try lots of times ,but always failed,so I hope someone can give me help~
the self-made SOPC component is connected to read master port of DMA, SDRAM is connected to write master port of DMA.
the setl-made component is connected to avalon bus as a slave interface.when I use "IORD"to read the component,it is right,but when I connect is to DMA,DMA transmits failed~
if((rx= alt_avalon_dma_prepare(rxchan,rx_buffer,1024,done_t,NULL))<0)
printf("rxchan receive failed.reason: %d",rx);
exit(1);
dma_prepare always failed, if the self-made component has some problems (the component consist of a FIFO which connected to avalon through slave port )??
The NiosII software code is attached
the pogrammme is very urge,and there is nobody around me can give me advise,so I hope you gurus can give me some hints~
thanks very much~~
/* begin receive data*/
exit(1);
after running,niosII console:
rx=-28;
I check the meaning of "28" in altera_avalon_dma.h:
start = priv->tx_start;
end = priv->tx_end;
slot = &priv->tx_buf[end];
next = (end + 1) & ALT_AVALON_DMA_NSLOTS_MSK;
if (next == start)
return -ENOSPC;
so I guess that there is no room in memory,but I am not sure which memory has no room and why it has no room,so I delete my signaltapII file so as to let more room off,but the error is still there.
I will keep trying~
hi,
I have solved the above problem,that is ,the data writen into the FIFO can be transfered to the SDRAM by the DMA .
here I have some feelings which be shared with yours.
1: DMA transmition ,FIFO (slave port attached into Avalon bus) to SDRAM,because of reading the same address(FIFO base address),so you only need to open received channel(rxchan),and set iocl(mode,RX_only),then ,prepare .
2:there seems the SOPC can do lots for you,so you need not care about the details too much:)
best regards
