5993 Discussions
"Using Triple-Speed Ethernet on DE2-115 Boards" doesn't work
The tutorial files are located here:
ftp://ftp.altera.com/up/pub/altera_m...2.0/tutorials/ (ftp://ftp.altera.com/up/pub/altera_material/12.0/tutorials/
I can't attach the Qsys system, but I can attach a screenshot of it....
The problem is the ISR never gets called to receive the packet... It does appear to send though
here's what shows in the debug window:
Opened scatter-gather dma transmit device
Opened scatter-gather dma receive device
send>
TEST1234TEST
TEST1234TEST
send>
There should be a receive in there, but I can't figure out why... the Qsys and QuartusII part of the tutorial built without errors... I'm guessing that something isn't hooked up correctly in the Qsys picture...
The system and code works, problem was ethernet cable between eth0 and eth1
how do u solve the ethernet cable problem between eth0 and eth1?
