5931 Discussions
romstyle="MLAB" attribute is ignored
SLabe
Partner
Looking how to infer a small ROM into MLAB. When using the following code, the resulting altsyncram still reports RAM_BLOCK_TYPE set to AUTO instead of MLAB. I use the following code, tries romstyle on q and rom with same results, AUTO resulting into M10K being used. All assignments are default.
// ROM Test
// Quartus Prime Verilog Template
// Single Port ROM
// Declare the ROM variable
(* romstyle="mlab"*) reg [DATA_WIDTH-1:0] rom[2**ADDR_WIDTH-1:0]; /* */
reg [(ADDR_WIDTH-1):0] addr_reg;
initial
begin
$readmemb("baseline.txt", rom);
end
// Initialize the ROM with $readmemb. Put the memory contents
// in the file single_port_rom_init.txt. Without this file,
// this design will not compile.
// See Verilog LRM 1364-2001 Section 17.2.8 for details on the
// format of this file, or see the "Using $readmemb and $readmemh"
// template later in this section.
always @ (posedge clk_50)
begin
addr_reg <= addr;
q <= rom[addr_reg];
end
KhaiChein_Y_Intel
I would like to duplicate the issue. May I know what edition (Pro/Standard) and version you are using?
KhaiY
SLabe
Partner
Hello KhaiY,
I'm using Quartus Standard 18.0 for Windows. Here is my full code snipet if you wish to reproduce. Three scenarios:
  • Code as is, all settings default, it results in the ROM being implemented with one M10K.
  • romstyle removed, all settings default, it results in the ROM being implemented generic logic due to its small size. (Uninfered RAM logic)
  • romstyle removed, "allow rom size recognition: on", it results int the ROM being implemented with one M10K
Example Code:
module ROM_init
#(parameter DATA_WIDTH=8, ADDR_WIDTH=5)
input clk_50,
input [(ADDR_WIDTH-1):0] addr,
output [(DATA_WIDTH-1):0] q_o,
output [(DATA_WIDTH-1):0] p
// ROM Test
// Single Port ROM
assign q_o = q;
reg [(DATA_WIDTH-1):0] q;
initial
begin
end
begin
addr_reg <= addr;
q <= rom[addr_reg];
end
// IP Catalog version for comparisson
//rom1port rom1port_inst (
//.address ( addr ),
//.clock ( clk_50 ),
//.q ( p )
endmodule
// For reference baseline.txt is as follow:
00000000
00000001
00000010
00000011
00000100
00000101
00000110
00000000
00000000
00001000
00010000
00100000
01000000
10000001
10000010
00000000
00000001
00000010
00000011
00000100
00000101
00000110
00001000
00010000
00100000
01000000
10000001
00001000
00010000
00001000
KhaiChein_Y_Intel
May I know what device you are using? It would be great if you could provide the QAR archive file as it contains all the settings same as your design file. To generate the archive file, click on Project > Archive Project
KhaiY
SLabe
Partner
This is targeting Cyclone V.
See attached project. Thank you!
KhaiChein_Y_Intel
I can duplicate the error, the ROM type is set to AUTO even the romstyle="MLAB" attribute is used. I tried to set the romstyle to "M10K", the ROM type is set to M10K in the Fitter report under RAM Summary, which is the correct behavior. I think this is the error on MLAB setting only. I will file a case to engineering for this error. Thanks for reporting this to us. Coud you use the IP Catalog to instantiate ROM with MLAB type as a temporary workaround?
KhaiY
KhaiChein_Y_Intel
May I know if you are able to proceed with the temporary workaround?
KhaiY
