5276 Discussions
run a c program using nios 2 command shell
I am trying to run a .c file from nios 2 command shell but not able to. I know how to run .elf using nios2-download -g hello_world.elf. I also know how to convert .c to .out using nios2-elf-gcc hello_world.c
But how do i get a .elf from .out or .c, so that I can use nios2-download command to run?Or is there any other command like nios2-download specific to .out or .c?
Thanks for the reply,
Amjad
I hope my question was clear.
Let me rephrase. I would like to know how to run a .c file using only Nios 2 command shell prompt..
Thanks..
You can't just generate a binary file from a single source code, you need to link it with the C library and the drivers.
The easiest way to do that is to write a makefile and use make. You can have a look at the makefile generated by the Nios SBT as an example.
Thank you for the information. I will try your suggestion...
