I'm trying to develop a simple application using the push buttons on the Cyclone iii development board. The project cycloneIII_3c120_dev_my_first_fpga compiles and works correctly. However in that project the push button signal is processed by a megafunction. I have modified that project by adding the following module to try to access the push buttons directly. module push_button1(megaf_in, user_pb, user_led, user_led7); input [7:0] megaf_in; input [2:0] user_pb; output reg [6:0] user_led; output reg user_led7; always begin user_led[6:0] <= megaf_in[6:0]; // This is passing through data from the megafunction and is working. user_led7 <= user_pb[2]; // This is passing through a pushbutton state and is not working. end endmodule Can anyone tell me why the 7th led doesn't respond to the push button. (The pin assignments have been confirmed using the original project.) Thanks in advance! MonteLink Copied
i am also try to do
