6397 Discussions
sof file is not loading in Agilex f AGF014R24B2E2V
madhan_m
I am using Intel Agilex AGF014R24B2E2V. after generation of the .sof file when I am using Programmer to load .sof into Board via JTAG; it is failing at 14% and in the Quartus mesages window it is showing an error that
" Detected a PMBUS error during configuration. Potential errors: VID setting is incorrect in the Intel Quartus Prime project. The target device fails to communicate to a smart regulator or PMBUS master on a board " how to rectify this issue?
Ash_R_Intel
Agree to @sstrell. Please follow the post. VID settings are required to be set correctly as per your board settings.
