6416 Discussions
stratixV GX development kit && display port
Recently ,I have studied the Stratix V GX development kit board with the display port daughter board. I downloaded the displayport design example 13.0(tx only)from the altera website.
after compling,i already got the .sof and .elf files.but i got nothing after running these.
I follow the instructions from the pdf files one by one. would anyone give some advises ?what's wrong with it?thank you very much.
I located the question.the sof is downloaded well.but the elf file isn't.I make some breakpoints in the main.c files. I found that it stoppedafter "printf(starting...\n)" that means the following "bitec dptx init()"didn't work.does anyone tell me how to config the DP core?thankyou verymuch
