6371 Discussions
system-console, close_service not working?
covfefe
I am trying to close_service & claim_service (to handle disconnected devices).
Unfortunately I am unable to make it work.
  1. How can I close_service pathA, then claim_service pathA ?
  2. Or, alternatively close all service paths, to keep the service console, but start fresh?
close_service master {%s}; claim_service master {%s} m
Response:
CLIENT (sock2532): close_service master {/devices/5AGT(FD3H3|MD3G3)|5AGXBB3D4|..@1#USB-1/(link)/JTAG/(110:132 v1 #0)/phy_0/master}; claim_service master {/devices/5AGT(FD3H3|MD3G3)|5AGXBB3D4|..@1#USB-1/(link)/JTAG/(110:132 v1 #0)/phy_0/master} m
SERVER (sock2532): Invalid command from the client
ErrorMsg : Could not claim service at /devices/5AGT(FD3H3|MD3G3)|5AGXBB3D4|..@1#USB-1/(link)/JTAG/(110:132 v1 #0)/phy_0/master: Channel is opened
    while executing
"claim_service {master} {/devices/5AGT(FD3H3|MD3G3)|5AGXBB3D4|..@1#USB-1/(link)/JTAG/(110:132 v1 #0)/phy_0/master} {m}"
ErrorCode: NONE
ErrorInfo:
    while executing
    while executing
"claim_service master {/devices/5AGT(FD3H3|MD3G3)|5AGXBB3D4|..@1#USB-1/(link)/JTAG/(110:132 v1 #0)/phy_0/master} m"
    ("eval" body line 1)
sstrell
close_service has to point to the claim path, not the service path (in your case, the master service path).
claim_service will point to the master service path.
covfefe
Isn't this what I am doing?
sstrell
No, it looks like you are using the master service path for both close_service and claim_service.  A claim path is usually created like this in a script after you've created the service path (mpath in this case):
set claim_path [claim_service master $mpath {} {}]
So then close_service can simply be:
close_service master $claim_path
covfefe
Thank you. Right now, if I try to
and the channel is open, I get an error message. How can I bypass this issue, without knowing the claim path? I assume I first need to close the channel, then do claim_service.
An attempt at
is_service_open master {/devices/5AGT(FD3H3|MD3G3)|5AGXBB3D4|..@1#USB-1/(link)/JTAG/(110:132 v1 #0)/phy_0/master}
does not work, and returns 0 regardless.
An attempt at
get_claimed_services master;
returns no values.
set claim_path [claim_service master {/devices/5AGT(FD3H3|MD3G3)|5AGXBB3D4|..@1#USB-1/(link)/JTAG/(110:132 v1 #0)/phy_0/master} {} {}]
 crashes by saying could not claim service, channel is open
sstrell
So you've done claim_service previously but you don't know what the claim path was?
What if you just write the whole thing out:
close_service master [claim_service master {/devices/5AGT(FD3H3|MD3G3)|5AGXBB3D4|..@1#USB-1/(link)/JTAG/(110:132 v1 #0)/phy_0/master} m]
covfefe
This does not work.
As the previous message says, this command crashes
CLIENT (sock2472): claim_service master {/devices/5AGT(FD3H3|MD3G3)|5AGXBB3D4|..@1#USB-1/(link)/JTAG/(110:132 v1 #0)/phy_0/master} m
SERVER (sock2472): Invalid command from the client
so the following command as well
CLIENT (sock2472): close_service master [claim_service master {/devices/5AGT(FD3H3|MD3G3)|5AGXBB3D4|..@1#USB-1/(link)/JTAG/(110:132 v1 #0)/phy_0/master} m]
Yes, claim_path is unknown (application reboot)
ShengN_Intel
Or may be try to get service path first like below:
set m_path [lindex [get_service_paths master] 0 ]
set c_path [claim_service master $m_path ""]
close_service master $c_path
Sheng
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution and give Kudos.
ShengN_Intel
Any further update or concern? Does your problem resolved?
ShengN_Intel
Since there are no further updates or concerns for this thread, I shall set this thread to close pending. If you still need further assistance, you are welcome reopen this thread within 20days or open a new thread, some one will be right with you.
covfefe
Thank you, the following successfully closes the service path:
set m_path [lindex [get_service_paths master] 0 ];
set c_path [claim_service master $m_path ""];
close_service master $c_path;
Now, to be able to re-claim an existing path, I first need to be able to check if it is closed. However, this command returns 0 regardless of the status (open or closed).
 Which then errors on the next command to claim it
CLIENT (sock2256): claim_service master {/devices/5AGT(FD3H3|MD3G3)|5AGXBB3D4|..@1#USB-1/(link)/JTAG/(110:132 v1 #0)/phy_0/master} m
SERVER (sock2256): Invalid command from the client
Is it possible "close_service master" does not really close it?
ShengN_Intel
After close_service, you have to get_service again in order to claim_service. claim_service can't be done straight away after closing service.
Sheng
